Even a good converter will be too loose with that gear.
It all looks really good to me except for two things. First is the carburetor. Although you need a larger one, that will pretty much only effect mid range and top speed. But, the larger venturis of a larger carburetor would help a little. The biggest problem I see is with the gear and the converter. They are mismatched. Either get a converter close to stock, or step up to a 3.91 or 4.10. Everything else in your combo matches up to gears lower than a 3.55, IMO. To me, the most logical choice would be a Holley 3310 750 and a 4.10 gear. That would set it on fire. All this is just one peon's opinion of course.
I respectfully disagree. I ran 3.91s with a 28" tall tire and a 8" 3800 stall T/A converter on the street for years. It was certainly not sluggish
What size tire is on the car ? a 26" tire and 355 gears will feel the same as a 391 with 28" tall tires.
i completely agree with this with the exception of the 4.10 . a nice holley 750 ~ a 2800-3200 stall ~and a 3.91 and you will be in business..in my HO. this combo with your cam choice should run very decent, given your timing is exactly where it needs to be.
How does it pull to wide open when you say the rear plates are only open 1/8 of the way.
Is it the air door at 1/8 or the bottom throttle plates at 1/8 open. BIG DIFFERENCE!
Think about it. Regardless of your experience, if your gear is too high, that requires more torque from the engine to get the car moving. More torque makes any converter flash higher. You also had 3.91 gears which would certainly not be sluggish. 3.55s on the other hand would have made your combo act entirely differently. Differently in this case would be slower because the converter would flash higher wasting power. Yours was fast because it was geared correctly.
Its the throttle plate, I rechecked it after the post(w/ the carb pics) because i made that mistake of looking at the air door the first time.
If i manually move the throttle linkage to WOT(making the cable irrelevant) it still doesnt fully open those rear plates.
Your not taking tire diameter in to consideration and theres a big difference in driveabilty a cheap converter and a quality converter. Just ask anyone that bout a $200 converter and replaced it with a $800. Just because it flashes high doesnt mean it pull hard. How much is the converter slipping ?
Either way I dont feel the converter is his problem if its a PTC they are usually fairly efficient . I would finish up the distributor and either tune the carb (which I feel theres nothing wrong with an edelbrock) or replace it with a Holley that will also need tuning.
With a short 26" tall tire gearing isnt the issue either.
I know it does....I understand that completely. What I was saying was that for the sake of simplicity, I was leaving tire size OUT of the equation. Just direct effect of gear on converter is what I was talking about. Nothing more.
Carb isn't opening fully and people want to change gears and converters. I feel dumber today.
Good luck to the OP...
Kyles Demon with less cam, less head and less gear/converter would run circles around this current combo.
You should expect nothing less from an online diagnosis.
Start from the beginning. Verify were top dead center is with a piston stop and mark the balance with timing tape. Get the distributor curved correctly an get someone to help you set up the carb. Worry about the rest after.
So the throttle plates are only open 1/8 when you manually open the linkage? You have a MAJOR issue with that if the case. Do the primaries open to straight up/down or very close when using pedal and manually?
Is the choke assembly locking it up? Any interference with intake and carb linkage?
Have you tried to remove the carb and see if the linkage will open fully?
Until you get the ignition and full throttle issue solved, anything else is just a waste of time.
IMO, the converter and gears are not the issue here. Especially with the short tire he has.
