AdamR
Big Member
I know, that's a whole discussion in itself. LOL
I agree but for the sake of right now I say plug it and leave it plugged LOL
16 initial is ok but you need to weld the advance slots up a bit to get total down to 36-38 then swap some springs around to get it all in around 2500rpms.
Have a friend hold the gas to the floor (motor off) then see if its opening the throttle blades all the way buy moving the lever back by hand.
Is your kickdown rods from a 4bbl car ?
That's probably the better way, that way you can tell if everything is working correctly.
16* initial is a good start. You might eek out a couple more degrees out of it. Ideally like Adam said you want 36-38 all in by 2500 at the most.
You are doing this with the vacuum advance unhooked and plugged, correct?
Yeah its plugged. At least when I'm taking the timing readings.
Probably not 4bbl kickdown. The last owner/previously builder kind of cut corners on virtually everything.
Maybe i'm looking at this wrong, so here are some pics:
Looking down the rear of the carb i see this plate(1st pic not wot) and at WOT(2nd), it doesnt seem to move.
What you are seeing in the secondaries is the air door plates. You need to put a screwdriver done there and open that up to see the actual throttle plates.
The kickdown, have someone hold pedal on floor, go under car and disconnect the linkage. See if it swings further back than where it is at full throttle. My guess is the upper arm is too short and not properly applying full range to the arm at your trans.
OR
Hold the throttle wide open, then push back on the kickdown rod at carb, if it moves back a bunch more you need to address that.
Ok, good deal on the numbers. In regard to the total... Did you rev higher, or stop at 4K? My impression is it will keep advancing even further. But... It's easy to recurve what you have for about $30. $7 in parts for the light advance springs from Mr Gasket, and the rest to a guy at a local muffler shop to weld up the last .25% of the slots in the advance plate. While the kickdown is not perfect, My impression is it's "ok". You can also use a very small bolt and nut and washers to make the slot in the adjuster shorter and get some of that kickdown back.
any only guides to taking apart one of these oem distributors to have this done?
I'd be thrilled if i could get the total timing right without having to re-do the ignition system to an MSD/pertronix. At least for now.
Did you check out the link I posted?
On the carb - There is an air door over the throttle plates in the secondaries. You have to hold that door open when looking down the bore.
On the last bit, was gonna do that today, but the pouring rain made things a little difficult. However, after getting what seemed to be an accurate timing made me think that it is not an issue.
yeah, i rechecked it earlier holding that air door open and the actual secondary plate only opened about an 1/8th of an inch at full throttle.
The accurate timing doesn't have much to do with it. If the thing has spun 10*, then the initial timing you think is 16 is really 6, and total is really 34, etc.
If the thing isn't running right at 10* initial, its a fair bet something goofy is going on. Of course that's low for performance, but it should at least run.
Also, its not really going to have a lot of oats at 3000 RPM, so that early shift is perhaps a large part of your problem.
Lots of good advice in this thread.
I think you will be wasting your money, time and creating a whole nother list of problems by changing the valve body.
Yeah that's a problem. You need to get the throttle cable to open the carb all the way. Maybe a stud location closer to the shaft axis.
5/8 throttle will be a dog.
