Looks like it's hittin harder too. You did somethin right! lol
AJ are you taking about this?I think i have found.....Ah....... smoking gun.
So to fit the bigger slicks, i had to move my leaf spring inward causing me to have to us off set shackles.
The offset shackles clear just fine on the right side however Not so much on the other side. My bumpers have them little bumper guards on them. they bolt to the sub frame and are both trying to share the same space.
View attachment 1715341640 View attachment 1715341641
crunch? what post #
It's amazing how a binding suspension will affect everything.Looks like it's hittin harder too. You did something right! lol
Yeah I guess I missed that.AJ are you taking about this?
Pinion is 4-1/2 Degrees nose down.
Agree thow, with as much as it twist, i kinda wish i would have when closer to 7. I think the back brace amplifies the look.
When i get the clamp for my GoPro, i'm going to see just how much the u-joint angle changes at the pinion..............
And yes i had a leaking line on the left wheel cylinder. fixed. I expected someone to notice a lot sooner
So what SS Spring would you have used on a e body that weighs 3860?
