Why not a 413 ?
Just curious why bore size is the deal breaker. What does a big block chevy have for bore size? 4.250 in 427s and 454s and 396 was much smaller and they all make good power.
Because you cannot find anything in a forged piston for a hotter build for the Chrysler stroke and rod length, unless you have pistons custom made. That's a thousand dollar cash outlay. Might as well go 440.
I would love a 505 or 543 stroker but around here you won't touch one under 5 grand for a machined/assembled short block. I would assemble it myself but still don't have the funds.
That's why I wouldn't even start one either they're just too expensive to get together and then all the accommodating parts..
my buddy has one in his 68 dart. I have a 413 MW bare block laying around here as well. At one point, they were the legend on the strips. Heck, Jan and Dean, the Beach boys, the Super Stocks, all made songs about the 413 MW dodges.
They didnt hold as tick to the max wedge 426`s tho . Why carry all that weight for less h.p. ??
As far as exhaust valves, the higher the compression the smaller the exhaust valve can be. Example- B1 2.30 intake 1.78 exhaust. I run those sizes in my 440-1 heads. Unfortunately i found out they made the same power as 2.25/1.81 sizes. So with that being said, a 413 block that will safely go to 4.250 or 4.280 could make good power , and if the block is cheap to buy or already owned, that will offset some of the piston costs. Also how good is the main webbing on these blocks? If it is better than a 440 that is another BIG point in its' favor if you plan on making a lot of power.
If it’s an industrial block it’s the same webbing as the other industrial HD 440 blocks, same as the motor home 440 engines.
The only RB that has a different/reinforced block is the 426 Max Wedge. The 413, 440 blocks, regardless of industrial or passenger vehicle, were physically identical with some blocks having higher nickel content, which claims to be slightly more durable. There’s been all sorts of big block myths for decades, 98 percent end up being just that, myth.
Industrial/truck blocks have extra cold weather ribbing on the outside of the blocks.
My advice, if you’re trying for a budget build, if you have a 413 already, rebuild it, run it. If not, may as well buy the 440 and start there. If you already have it, then it makes no sense to switch to a 440 economically as the cost to buy a 440 block will likely offset the cost of the more expensive pistons and then some.
This is from 440 Source.
Everything you've ever wanted to know about blocks and more...
Written by Brandon Nicholas in 2003.
Copyright www.440source.com
If you haven't read our page on An explanation of Chrysler's part and casting number system, be sure to check it out also.
Blocks are one of the most misunderstood aspects of building a big block Mopar engine. Never has there been more misinformation, propaganda and rumors floating around. In the many years we have been involved with the big block Mopar engine, we have seen and owned many many hundreds of used core engines. We have used this opportunity to try and keep records as much as possible as to different advantages and disadvantages that various blocks offer. All the facts listed below are the result of our independently testing, measuring, sonic checking or otherwise gathering information directly from original sources: either the blocks themselves or the original factory drawings (blueprints) that Chrysler used to manufacture the blocks. This eliminates all chance of secondhand information, rumors, marketing or sales talk, etc. Hopefully this page will help hobbyists, restoration experts, and racers decide which choice of block is best for them.
First, let us address the biggest myth of all:
For many years it was thought that late model blocks were thin wall and should not be bored more than .030 over.
On page 198 of the Mopar engines manual, (the 8th edition) in the "B-RB Engines (block) section, it states: "The 1976-1977-1978 blocks for the 400 and 440 are a thin wall casting design. As such they shouldn't be overbored more then .020." This quote can now be found on page 58 of the new "Big Block B/RB Engines book from Mopar Perfomance, part # P4876825
Two pages later, (pg. 200) under "Boring and milling specifications," the manual states: "...The newer blocks (1975-1978) should only be bored .030" max., because they are thin wall castings. This quote can now be found on page 64 of the new "Big Block B/RB Engines book from Mopar Perfomance, part # P4876825
Then, in the May '98 issue of Mopar Performance News, in an article titled "The Big Block Story" on page 16, it states: "The newer production 440 blocks, '73-4 to '78 are thinwall cast, so you can only bore them .020"..."
So, as you can see, even these multiple sources of info which come straight from Chrysler engineering contain different information. What is the Mopar enthusiast supposed to think? Are the thinwall blocks from 76-78, or are they from 73-78? Can you bore them .030, or is .020 the maximum? We will answer all these questions once and for all based on scientific fact. The purpose of citing these books and articles is not to make Chrysler/Mopar Performance look bad. As racers and hobbyists, we are grateful for the resources and aftermarket parts that Chrysler makes available. However, it does demonstrate how even someone who does their research could be easily confused. So, it is to the benefit of everyone involved to help spread information which is known to be true, even if goes against popular thinking.
So what is the truth? Get ready for this.
There is no such thing as thinwall blocks. They DO NOT exist.
We have sonic checked over 50 blocks, and have found absolutely no evidence that later model blocks have cylinder walls that are any thinner then earlier blocks. In fact, we have found later blocks to have less core shift, meaning the cylinder walls are of a more uniform thickness all the way around. This makes perfect sense, considering that B engines were in production for over 2 decades. During this time, it would be expected that there would be small improvements in the technology of casting processes, quality control, etc, which would help create a better product.
There was also an article from Mopar Action magazine by Andy Finkbeiner of AR Engineering in which they sonic check 20 blocks and come up with the same findings we did. They also explain how statistically 20 blocks is enough of a sample to estimate the rest of the 440 blocks out there. We've tested over 50 with the same results. This article also has some great info regarding hardness of the iron used, in which they find that the earlier blocks do have slightly harder cast iron, by about 10%.
Another issue is block weight, or the quantity of cast iron which is actually used in the block. Like the Mopar Action article, we have weighed many blocks and have found later blocks to weigh more, or have more cast iron in them. Since the reasoning behind thin wall blocks is that the factory used this practice in the late 70's to save money on iron (which is a known fact with SB Chevy engines), the fact that later blocks weigh more shows that Chrysler had no intention of using less iron to save money. Which is great news for us racers and performance enthusiasts.
So, the bottom line? Save and use those late model blocks. And go .060" over with 'em all day long. Also on that note, we know of several machine shops that have been going .060" with late model blocks for over 20 years with no problems.
On the outside, I was referring to his main webbing question
Once again from 440 source
Fact #2:
There are SIGNIFICANT differences between blocks in the main bearing saddles and support webbing.
Lets start with "RB" raised deck blocks.
What you are looking at above is the number 2 main bearing support on a 75 or earlier 440. This is the area that surrounds where the top shell of the main bearings fit into the block, and the supports that lead from this point diagonally up into the block, to the bottom of the cylinders. The thickness of the main support is labeled "A" while the thickness of the metal forming a "shell" around the bearing is labeled "B." These are the two areas that differ considerably among different blocks, and we will focus on measurements of these two areas. Please note that all the measurements we are using in this section are averages off of multiple blocks, to eliminate the possibility of one block having more or less iron used as an irregularity. The "A" measurement typically is between 1.900" and 2 inches. "B" typically measures about .375" (3/8") All 440's cast before '76 and some after will have these main saddle support measurements. This includes ALL 2536430 (1966-72) blocks, ALL 3698830-440 (1973-74) and some 4006630-440 (Late 1975-79) blocks. I have also found 426 Hemis, Max Wedges and even Mopar's megablocks to also use these measurements. Now on to the late model 440 blocks...
SOME 440's cast in '76 and later have CONSIDERABLY thicker main saddle supports. The only block we have found to have these supports are the 4006630-440 casting #, which was used from late 75 until the end of production in 1979. In case you have heard that 440's were discontinued in 1978, this was for cars only. 440's continued to be offered in trucks and motorhomes all through 1979, and we have had many 440 blocks stamped with the 1979 model year on them.
Shown above is a picture of a 4006630-440 (1978 model) 440 block. The "A" measurement typically is about 3.190". This is about 60% thicker than the early 440 blocks shown above. "B" typically measures about .520", which is still about 40% thicker. The blocks with these thicker supports were not cast during any specific date period. There is no external markings or numbers which show they are different from the other blocks. They DO seem to be more commonly used for truck motors, however just because you have a truck 440 does not mean it will automatically have the thicker main supports. One important fact is that while 4006630-440 casting # blocks are the only blocks we have found to have these thicker supports, not all these blocks will have them. There appears to be no other way to tell if a block has them or not other then actually looking at the supports themselves. Without the crank and rods removed from the block, it is very hard to tell.
Now on to low deck "B" blocks.
Shown above is a #2 main saddle off of a 1970 model 383. We have found all 71 and earlier low deck "B" blocks (including 361's, etc) to have this type of main saddles. "A" in this case measures between 1.900 and 2 inches, and "B" measures about .350" These are probably the smallest measurements of all the big blocks. Now lets compare this to the 400 blocks below.
Shown above is a 3614230 (1972-73) 400 block. These are the thickest of any blocks around, bar none. we didn't even bother to mark the "A" dimension because it is so huge it is practically off the map, and the "B" dimension came in at a whopping 1.350! When you compare this to the 383 and 440 pictures above it makes them look like a joke. One important side note however, is that there are some 3614230 blocks that DO NOT have the thick main supports. Before you spend hundreds of dollars to ship that block across the country, make sure it has the thick mains!! Be sure to always measure or at least see a clear picture.
Moving on, if you can't seem to find the superblock above, a good second choice is shown above; a 1973 400 block, casting #3698630. Notice the main saddle supports are CONSIDERABLY thicker then both the 383 AND the pre-76 440 shown above. "A" in this case measures 3.750" and "B" measures .575! This is close to a quarter inch more metal in the area surrounding the bearing shell, and the support leading up to the cylinder is almost twice as wide! We have found the thickness of "B" to vary slightly, even among blocks with the same casting # cast during the same month of the same year. In this case we have found blocks between .525 and .575, but still worlds above the .350-.375 measurements listed above for 383's and 440's. Combine this with the fact that the cylinders are shorter (since the block deck height is shorter) compared to an RB, and you can see that a 400 block is ABSOLUTELY stronger then any other block made.
But wait, you say. "I know the early 400 blocks are good...I heard the later ones went back to thin supports...." WRONG (well mostly.)
Shown above is the #2 saddle on a late model (76-78) 400 block, casting #4006530-400. The "B" measurement remains the same as the early 400 block at about .525 -.575, while the "A" goes down to roughly 3.300, making the support only less than half an inch narrower then the early 400 (still almost 90% of the width), and still over 1 1/4 inches wider then 383's and early 440's.
The end result? Pretty ironic. Chrysler famed powerplants that dominated the muscle car era, 383's and 440's have the weakest supports of all, while their "smog" motors, 400's and late model 440's, which couldn't get out of their own way, have blocks that are considerably more reinforced and able to handle much higher power levels.
There is absolutely no physical difference between a block with an HP or HP2 stamp and one without.
From 440 source
The strengthening "rib" or support can be found on all 440 blocks starting approximately with the 1969 model year, and ALL 400 blocks.
On the side of the block just above the freeze plugs, sometimes you will find a strengthening support or "rib" cast into the block. This was started in the 1969 model year on 440's (E 440 code on the ID pad), or approx mid '68 casting date. This is an improvement that was instituted around this time and lasted until the end of production. Every 400 block we have seen has this support, and NO 383 blocks we have seen have it, (Another small reason to build that 400 stroker...) Yes, blocks do occasionally crack around the freeze plug area, so it isconsidered desirable to find one that has this strengthening rib, however it is not a necessity, and certainly no reason not to use a nice 66-68 440 block you may find or have. As mentioned above, this rib has nothing to do with HP or non-HP. Notice also there is a slightly raised area in the center of the block, starting at the oil pan rail and leading up the skirt to the freeze plug area. The machined part of this (by the oil pan rail) was used to stamp the engines serial numbers. When an engine has the strengthening rib, it will usually have this pad as well. This explains why serial numbers were first used in this location in 1969. The only exception we have found is 70-71 383's... they will have the pad without the rib.
Shown above for comparison is an early block without the rib or pad.
One other addendum.. Some 413/426/440 blocks commonly known as "industrial / cold weather or heavy duty truck" blocks have another pattern all together, with even more reinforcements. Shown below is one of these.
The thickness of the mounting lugs or "ears" was increased starting in 1975.
One fairly common problem that big blocks are plagued with is breaking off of the somewhat fragile "ears" or "lugs" on the side of the block that the motor mount support brackets bolt to.
(Typical broken motor mount ear- common)
The engineers at Chrysler must have realized this, because starting in the 1975 model year (along with some other changes listed below) the thickness of these lugs was increased by about .200". This was done with both 400's and 440's.
Early (pre 75) block mounting ears on the left. Later (76-79) block mounting ears on the right. The difference is obvious. We rarely see the later blocks with cracked ears. Yet another reason to use late model blocks.
