Will at 1968 Plymouth Valiant radiator fit a 1965 Valiant?
slant225go
Member
Hello my 65 Valiant radiator is going south and I can not find a new one for it anywhere online. Would a 68 Valiant radiator work well and fit?
My 65 has a slant 6 225.
you may have to cut the lower radiator
support under the radiator and bend it down an inch.
65 L6-225 16 3/4 high x 19 1/4 wide x 1 1/4
67-69 L6-170/225 17 1/2 high x 22 wide x 1 1/4
Lee
Why not just get yours recored. Have had all 4 of my 65 radiators recored to a 3 core when the funds permitted it. Right at $300 each and now good as new.
I just put a 22" rad from a 68 Dart in my 65 Vart, Rad support openning is perfect. Drilled two holes each side of the bottom of the rad brcket to line up with the rad support holes. Top holes lined up perfect.
I have a 26" wide truck radiator in my 65 Valiant. Cut the opening a bit, but
other than that an easy install. Cools great in front of the built 360.
