Will it fit/ 84 Rampage
dartcuda
Mopar Or No Car
Springfield, Oregon
I have a 84 Rampage and I have allot of play in the p/s front wheel. I had changed the bearing before but it still has play. Now what I am wondering is if the hub assembly off a 92 LeBaron coupe would work. The only thing I can see deferent is that it is a 5 lug compaired to a 4 lug it has now.
where is the play in the wheel?
up and down?
side to side?
in and out at the top or bottom?
It's all around. Doesn't matter weather you are doing it from top to bottom or side to side. If it was a rear wheel drive it would be as if the nut was loose on the hub.
L body's use the same bearing as the other front drivers, up to 88 (could be 89) axles are different lengths, but hub assemblies are interchangeable from L body 4 lug to other FWD body 4 lug.
