Wilwood brakes for my Dart
darndart
Surrey, ND
A buddy of mine decided to go strut front end on his 70 Duster, so I bought his Wilwood set up for my 73 Dart Sport. I was curious as to what master cylinder to run with the Wilwoods? I would like to use the aluminum bodied Mopar master cyl., but not sure which one to use. They are 4 wheel disc, manual set up. Should I also bypass the orignal proportioning valve, and just use an adjustable vavle to the rears? Any help would be great appreciated. Thanks.
I called Wilwood when I did mine. Suggest you do the same. They suggested a stock aluminum master from an Aspen with the large bore - 1 1/8 I believe. Mine has rear drums. I bypassed the stock distribution block and used an adjustable proportioning valve.
they sell some nice dist. block / switch assemblies ...summit and speedway both have them.
work nice allowing adustment , plus split the fluid to both front wheels.
have used them on a couple disc swaps i have done. brake light switch is nice for the older cars too
Your master cylinder bore size will depend if your brakes are power assisted or not.
