Windshield Wiper Arms
Soren
Salem, Oregon
Are there any modern replacement windshield wiper arms available that will fit and early a-body so that you can use modern windshield wiper blades?
Thanks!
I am not sure about the other years of Darts, but on the '63, the arm and wiper blade is all one piece. You swap out new rubber, but not the entire blade like on modern wipers.
Thanks!
63-64 used a nut to attach the wiper arms. 65-66 were press on arms. The other post probably lists replacement blades for those years.
Interesting. That means that my Dart has had the wiper arms replaced at sometime since the blades are pressed onto the arms (almost looks like a tiny spot weld).
I was referring to how the wiper arms are attached to the pivots at the cowl, not how the blade holders are attached to the arms.
Thanks! That's just about exactly what I was looking for.
Did you buy the Anco 41-03, and did it come with the adapter?
Non of the listings I can find include the adapter.
Never mind! :BangHead:
Just ordered arms & blades from Rock Auto, they list the adapters! :)
