Shane
Hello again
So I am looking for thoughts/advice on my newest idea.
My motor is a 70's 340 all stock internals, ld 340, headers, holley dp 600cfm, and a purple cam to which I do not know the specs.(this is the part that has bugged me since day one, and the main factor for my winter project idea)
The motor had its bearings done when I got it 8-10000 miles ago.
The first thing that could kill my plan is, is it possible to change cams with the motor in the car?
If it is, then I want to have the spare set of X-heads I have cleaned up, rebuild a 750 DP I have, and get a modern cam that will work best with my set up( recommendations from you guys)
The car is my summer daily driver, its got an overdrive 4 speed, with 3.73's in the back.
any thoughts are appreciated
Thanks!
Shane
Thanks!
Shane
