Wilson_
Member
I have a few questions,
I took apart the dash trying to figure out why the wipers were only moving half way and found that some one moved the arms around.
I need the clips? and what else
Second question is. when rolling the pass side front window down the entire assembly (ie; wing window, everything) moves down and kind of rocks back.
I took the door panel off and found no loose bolts on the regulator, or missing ones I could see.
I will get some pics tomorrow.
Thanks!
Thanks!
