wiper issue?
ltrripp11
gentleman
got a wiper issue im trying to figure out on a 72 340 duster. when i turn my wipers on the arms will come up half way and stop. when i shut the switch off they will finish there sweep, go back down and stop. its a 3 speed and dont matter what position the switch is on and wiil do the same thing. i know it is not the switch because i just replaced it with a new o.e.m. unit and it does the same thing. also i have a good used spare wiper motor i plugged the harness into without bolting it up and this one also does the same thing. what component in the system would cause it to behave like this? thanks.
The wiper motor requires a good ground. Check that hard ground strap motor to firewall first.
