Wiring harness? Points or Electronic IGN
Electrical and Ignition
  1. RAVano
    RAVano Well-Known Member
    133
    72
    Mar 27, 2018
    Ct
    Local Time:
    2:24 PM
    Car in question is a 71 Dart. I'm about to start witing the car up. I'm installing a FiTech EFI and for ignition I'm running a 4 pin GM module. What engine wiring harness would be a better starting point for this? One with points or electronic ign.
  2. 67Dart273
    67Dart273 Well-Known Member
    39,930
    7570
    Oct 14, 2010
    Idaho
    Local Time:
    11:24 AM
    Since you are not running a Mopar ignition (GM HEI) it doesn't matter. Is the breaker points one cheaper? Are either wired for the 70/ later voltage regulator, and what are you going to use there for alternator/ regulator?
  3. RAVano
    133
    72
    Mar 27, 2018
    Ct
    Local Time:
    2:24 PM
    Yes point one is cheaper. It will have a magnum style alternator with the 70 on up Voltage regulator.
  4. 383Scampman
    383Scampman Well-Known Member
    1,397
    633
    Nov 24, 2013
    New Hampshire
    Local Time:
    2:24 PM
    points is easier , I believe you bypass the ballast resistor with HEI
    • Like Like x 1
