LXguy
Hey All:
Well, its been a long time getting together, but my Magnum swap into my Dart is finally ready to attempt to start. Picking up the distilled water on the way home, and then I'm firing it up.
Starting point: All stock, plus LD4B and Street Avenger..
Brought the Magnum home:
Some of the extra junk I stripped off of it:
Iron RAM heads on sale!
As it sits now:
This was a long project. I started on it in earnest last fall. To be fair I did also switch to front disks and installed a built 904, converted to dual exhaust, and swapped in an 8.75 while I was at it. Also, the crappy economy kept the spending to a minimum (hence the clutch fan instead of electric, and lack of double pumper).
Still need to get a couple of spark plug wires with 90* boots, check hood clearance, etc.
But anyways, tonight after work I'm filling the radiator, and hoping it works out.
Wish me luck.........
As it sits now:
