WIW Big Block HP manifolds
However the drivers side doesn't fit an A body unless your not planning to steer the car..
Actually, yes it will. If you cut the column case up close to the firewall and eliminate the column shifter and run a floor shifter. They will fit the 67 and up A bodies nice. Lots of them out there like that.
Learned something... Not that I'd put a big block in an A body, to me the great thing about A bodies is how light they are, the steering & handling are better without adding weight... A 340 or a 408 should be plenty IMO...
@abodyjoe will argue all day long about big block A bodies being nose heavy. He had a 440 in a 64 Valiant and loved how it drove. Then the big dummy sold it. lol
Unless you're stuck with a 69 Dart and the dreaded H code, or M Code.
:lol:
