Hello,
Using the wix 33737 to regulate pressure, been struggling trying to get a fitting to send fuel out to the engine as I am using 3/8" Nylon fuel line. Just found this fitting, it should be the part I need:
Quick Connect Male 3/8 Fuel Rail Hose to 3/8 Barb Adapter Fitting LS LS1 LS3
Hope this helps someone else, I already have $40 into fittings that don't work.
