WONTGETDUSTED
CRACKED-OUT MOPAR TECH JUNKY
- Joined
- Oct 6, 2006
- Messages
- 94
- Reaction score
- 0
Ok I'm Thinking Of Selling My 72 Duster.i Was Trying To Gauge A Fare Asking Price. Here's The Deal On The Car
72 Ply Gold Duster Was A Ps/mb/ac 318 Auto 7 1/4 Car
Car Needs Resto And Paint
Needs All 4 Floor Pans ,
Trunk Pan Sail Panels And The Left Rear Needs A Lower Qtr Panel Patch.passenger Door Has Been Replaced Its Rough But I Have A Good Replacement, Tail Panel Had Some Rust But I Got Another And Had It Patched
Frame Rails And The Rest Of The Body Is Solid And Pretty Stright
It Was Originally And Bench Seat Car But I Have 73' Buckets That Are Is Recoverable Shape With Good Foam(they Have Been Sitting Around In The Shed Since '96)
I Already Have A Cleaned And Painted Set Of Stock Leaf Springs And 8 3/4 Housing With A 3.23 One Legger Bolted In With Modifed Jeep Grand Cherokee Rear Disc Brakes(will Need Bp Axles)has Sbp Now
The Front K-frame(and Most Other Front End Stuff) Has Been Blasted And Painted And The Front Lower Control Arms Have The Factory Sway Bar Tabs And The 73 And Up Front Disc Brake Swap Has Been Done.
Also I Have Blasted The Entire Under Hood Area And Welded Up Some Holes That Were Unnessasary And It Has Been Shot In Sealer /primer
I Plan To Include The '70 New Yorker With A Good Running 440/727(drivetrain Donor) With The Car
I Also Have The Following
Schmaker Bb Adapter Mounts
B-body Hipo Manifolds
Factory 340/727 Driveshaft
2 Underhood Harnesses
3 Dash Harnesses
2 Xtra Complete Dashes One With Wood Grain One Not
1 A/c Box
A New Windsheild
Power Brake Booster And Mounting Bracket
Polished Taillights
Cracked But Repairable Sharktooth Grill
New Front Calipers & Hoses
The 15 Aluminum Riveted/no Hole Wheels Everybody Seems To Run On Dusters
Also A Bare Center Console
So Based On The Pics And The Parts I Have Listed What Do You Guys Think I Should Ask Or Accept...also The Car Is Currently A Roller
3 Dash Harnesses
1 A/c Box
A New Windsheild
Polished Taillights
