Wood's '408' low-buck Magnum build!
Tires to be:
Toyo R888R 275/40r17
SB Ford Aluminum Cylinder Head - 190cc - Pedestal Mount - Assembled
HP9008 aluminum head flow
Intake
.100" - 73
.200" - 120
.300" - 168
.400" - 203
.500" - 238
.600" - 240
Exhaust
.100" - 58
.200" - 104
.300" - 128
.400" - 146
.500" - 159
.600" - 166
#1---Head Flow Charts & Comparisons
Indy X 1.92 Stockers
Intake
.100" - 58
.200" - 109
.300" - 168
.400" - 192
.450" - 228
.500" - 236
.550" - 238
Exhaust
.100" - 59
.200" - 103
.300" - 145
.350" - 157
.400" - 165
.450" - 172
.500" - 177
.550" - 180
Your heads are ported?
I’d have them flow tested for your own knowledge.
I'm re-using my cam for now:
.005 @ 292 dur
.050 @ 226 dur
.200 @ 141 dur
.328 x 1.6 = .525 lift
112 LSA
108 Intake CL
I found out I have a 3 keyway crank, any thoughts on the effect of advancing or retarding it 2 degrees being helpful?
I wouldn’t put it in in further ahead than 108. You may want to back it up to 110 but I’m not sure it would be worth it.
Did a DesktopDyno for fun. Current and future.
future cam I put a 110LSA 248 duration @.050 .535 lift 108CL
Cam installed on 112 ICL
Piston to wall set at .0045
Ring gap set .026 top .030 second.
Just dragged a Ford 351M based stroker to the dyno .... made 430hp at 4700 rpm...yours should make more power.
Oh! OK. I agree, it’s a large part to install in the car on the engine. Did a 360 in a Duster two nights ago. I wouldn’t have guessed it would fit. No way no how. I do t know how he did it. We also have fresh paint, so that wasn’t getting in any danger that night!
I found a few items that will kick a burnout photo-op out a few days. I'll check back when that's wrapped up. Enjoy!
