J-man
While undertaking a 8.75 rear axle swap on my 69 dart I nicked one of the air lines to the rear air shocks. It released the pressure form the system didn't think much of it at the time since the car was on stands. The swap is now complete when I went to lower the car and it went (almost literally) to the ground. I believe that the previous owner who cheeped out on a lot of things put air shocks on the car to raise it back up and avoid replacing the springs. Also when I lift from the rear the rear axle travels up a lot more then it used to. I believe the springs are worn allowing the axle to travel. I talked with the guys at a shop and they said that it is really unlikely that the springs would be that worn out and the air shocks couldn't take that much load off the car. I installed new hotchkis shocks all around to hopefully help but no such luck. looking for someone with more experience on the subject so I'm not throwing $ at the wrong problem. Thanks for any input
