wtb 360 block
i have a 71 block in the machine shop going .030 now, think i am changing directions. also have a short block std. that is pending payment. and a 78 complete std. bottom heads were rebuilt about 5k ago, complete intake to pan 4bbl motor
I have one with low miles. 1979 block with stock dish pistons, bottom end etc. It has a brand new Purple stick cam in it with .478 lift 238 dur @ .050 110 degree lobe separation. It has timing chain/ cover and water pump ,oil pan and pulleys on it. Asking $675 B/O located in Hatboro,Pa. Not too far from NJ depending on where you are. send me a PM if interested.
i have brand new pistons kb 107 .030 360 30 with rings over ready for you cheap if you need them when you rebuild if needed
