[SOLD] WTB Thermoquad kickdown linkage.
Is TQ linkage different than an AFB or AVS carb??? I have 4 bbl linkage from a 273 4bbl 904 67 Barracuda. Sure looks a lot the same. Would that work??
I have kick down linkage from a 273 904 4 bbl car that looks the same. I PM'd you.
Woody...if Adam doesn't buy your K/D linkage, I may be interested. Do you have the correct throttle cable bracket as well?
I think the AFB/AVS rod is different and may be the one I already have. I could be wrong though. All I know is I have the original 2bbl set up and a second set that came with the car that was suppose to be a 4bbl set and doesnt fit.
I have the rod you need but I haven't done my engine swap yet to know if I'll need it. I hope you find 1 but if not I'll let you know about this 1. Did you try the fmj body site?
I already had that section. It was the from there to the carb I needed. I should have it in the lot I bought. Thanks
