Here you go, from the Chrysler Racing manual. You probably will not need pushrods, but a good idea to check them. You can also shim the rocker shafts upward.
Thanks guys that help out a lot. I was told that the lower bottom side bolt flange is to measure 1" and I measured mine and it measured .960, so ill chk measurements that 66's has pics of.
I had a set of unmodified X heads and the lower bottom side measured 1" so I think that's correct, but you can't beat the pic 66 provided from the racing manual to be sure
