x heads
BJR, You might want to double-check that. X's were used up through, I believe, 1970 - casting # 2531894. Then in '70 and '71, they started with the J-heads, which were cut for both, 2.02" 340's and 1.88" 360's. Then both engines were 1.88" in 1972.
Locomotion,
Your right for that casting # they are all 2.02s, the 915s came both ways, and they weren't just J heads they were also U heads, as I had 1 J and 1 U for the T/A setup that I had. Both of those were bought as a matched set with rockers and carried the 915 casting #s.
BJR Racing
Not 318 heads. The casting numbers are 915 I believe like the X and J heads.
That's great. I just luck out and have a 72 340. But I knew when I bought it that it had the 360J heads.
