[Found!] Yoke - 8 3/4" - 10 Spline - 7290 U joint - 2643008
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Hi all,
I'm looking for a good used 8 3/4" Yoke, 10 Spline, 7290 U joint. Shows 2643008 as its part number.
Prefer it with the OEM saddle straps, OEM bolts and lock washers, and OEM nut and washer, but not a deal breaker.
Greasy is fine as long as the seal surface and the U joint cup surfaces are clearly visible in photos
Let me know what you have
Thanks
Dana
