BARRACUDA340S
I went out to the garage to put the street tires back on. I went to look things over and the center section was pointing upward :shock: So I checked the U bolt's and they were tight but the perch wasn't sitting flat? So I looked a little closer and my buddy said the perches were bent. :shock: :shock: :shock: :shock: Sure enough they resemble a half circle now. It also bent my cal-trac bottom hanger's where the U bolts tighten down. I couldn't believe it. I tightened and TQ's the U bolt's before I left so I know they were tight. Now the rear's gotta come out and I have to weld new perches on. I need to find some stronger one's.
It get's better!
I went to put the street tires on and the lug's wouldn't go in for some reason. After fighting it for a few minutes I took the wheel off and checked the stud's. Yep,, I bent all of them on both sides. These were 1/2" studs. What a mess! I am done for the year!! and done racing. I was one run away from disaster. ops:
I'm gonna get the paint fixed and put her on block's till spring.
Sum Bich got some power though :thumrigh:
It get's better!
