JBrian
As my 1971 Duster project moves forward, I am looking for some input into the cooling system. As the car is on the rotisserie, Im going to open up the core support to accept a 26 radiator; so here is my current thinking for a cooling system for this setup:
Champion radiator: CC1643
Champion fan shroud FS374
The shroud accepts two 12 electric fans; what fan to use that the MegaSquirt can control or a Ron Francis XP-777 wiring harness with a delayed cooling system shutdown kit CD-36.
Any recommendations on the radiator, shroud or 12 fans?
As I said, Ill be going with the MegaSquirt MS3 and a F&B 85MM cable operated throttle body from EFI source. The motor will be cleaned up, new rings opened up and bearings with a Frank Racing 219/227 @ .050 camshaft and springs with the mandatory TTI headers and exhaust backed by an 833 overdrive 4-speed.
Ive been getting guidance from Wade (uncoog1) and Alex (AlexP) as they have both been involved with my build. The rest of the car will have Borgeson P/S, US Car Tool chassis Stiffening kit, all new suspension components, 4-wheel manual big bolt discs, 11.7 with Viper calipers, 16 steel wheels with poverty caps and A/C.
The goal is to drive and handle like modern muscle/pony car while looking like a stock 71 Duster 340, Alpine White, matt black 340 stripes, V24 blackout hood, cowl, fender, door tops with 340 WEDGE callout, black/charcoal bucket seats, etc.
I live in Texas, its hot in the summer and Im building a driver/show car that my wife and I can drive with the A/C in heavy traffic in August when its 100 degrees or cruise down the freeway at 75Mph;
Overheating is not an option!
