Thanks Redfish I was not sure of the year break.
Can you take a pic of the spedo back and the trans spedo pinion with the cable off?
The white plastic clip at instrument end appeared in 1968.
Did some one do work on the car before you got it? Something is missing there.The kink side did go to the gauges. On the other side of the speedo housing it has the little plastic pinion
