Cotter pins
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
What size cotter pins how the front end together? I was going to stop tonight and pick some up but not sure of the size. i need some for the strut rods, also need some for tie rods.
Just buy you an assortment. They already have them in a kit.
Believe me you will use some of all sizes at some point in time.
They aren't all the same size and length anyway so the assortment package will be your best buy.
It does use a roll pin but i want cotter pin in them. I dont think it would make a difference really because if you get to the point the pin is holding it on you have bigger problems lol.
Ok Ill buy assortments but which sizes to buy or do they sell a kit with several sizes.?
Well it might be ok to use a cotter pin but a roll(split) pin is harder and a snugger fit. A cotter pin is a soft pin and a loose fit in the hole. I am sure there is a reason Mapar used it and not the cheaper cotter pin.
The roll pin I believe is 1/8" so cotter pins that size by 1" long or so is what you need.
