Best roller rocker arms????
T67POWER
I was thinking of installing a solid cam in my 360 and will need a new set of adjustable rocker arms.
With so many on the market,i am looking to get all the info. i can on real world performance and durability.
What roller rocker arm set up do you use.
Are you satisfied or unsatisfied with the rockers performance.
If you used a set rockers that gave you problems, then please list it and what went wrong.
thanks :thumbup:
Ps I can't wait for summer>>>>>>>>>>>>>>.:burnout:
Heres a couple of pictures on my X-Heads.
A very good aftermarket roller rocker arm is the Hughes roller rockers. I have a set on my mild 318 and also and my 408 stroker. They are very high quality.
Ditto on the Comps. I have zero complains.
Also, Hughes has a good rep and there also at a reasonable price.
Pro Mag's
ok, i forgot to post pics of my hughes setup. maybe this will motivate you to getting the hughes. lol
my 408 stroker
my 318
Comp Cams Pro Magnum with Hughes hold down kit here. Nice hardware. The Hughes rockers are good too but they won't clear stock valve covers like the Pro Magnums will. Stay far away from the cheap chinese junk.
