Need speedometer pinion gear for 3:23 rear
pbiggs
Can't find the gear NOS or repo. I am looking for the a 21 tooth nylon pinion speedometer gear that's still useable for my 65 Barracuda with 4 speed and 3:23 rearend.
Thanks, Pat
Is it the OEM transmission or a later model?
Even with the newer, long shaft speedometer gears, I've never seen anything below 25.
Would the earlier transmissions go by a different chart? The '66 & up chart indicate some pretty tall tires for a 3.23 gear and 21 tooth speedo gear if it went that far.
Just trying to cover all the bases and maybe learn something at the same time.
It's the original 4 speed from my 65 Barracuda. Speedometer pinion gears changed in shape and size for 1966.
My 65 parts books shows part number 2204360 for a 21 tooth gear with 4 speed and 3:23 rear. Sure enough, the original taken out of the car has 21 teeth.
Thanks for responding. Pat
I have a 17, 18, and 19 tooth speedo gear if that will get you any closer.
Thanks, Mark
