jdhasa65cuda
I need a set of spitfire headers and was wanting to get in touch with Harold to order a set. The number i have for him is not correct. Any help would be appreciated
Cannot stress enought ...make the trans action c o d!!!!
I think theres an article in rod and custom or hotrod magazine showing a kit that consists of a bunch of yellow plastic tubes that you connect like legos and twist around. you basically buy the kit and build your own shape, then either send it to someone or weld it up yourself. The best fitting headers youll ever have. wish i remember what they were called.
thanks for the advice. Saw some pics of the tti headers installed and it appears that part of the steering column housing was removed to make them fit. Does any one have suggestions/ recomenndations for a custom builder?
Stock 273 manifolds are a lot less hassle.
On a street driven car, with a mild engine, headers are not worth a lot of power.
http://www.moparmusclemagazine.com/...pp_0307_mopar_crate_engine_exhaust/index.html
Looks like about 16 hp on a 300 hp engine.
To me $1000. for 16 hp was not worth the hassles, on a mostly street driven
car.
