demon seed
The Original Demon Seed
Thanks, it might work.
Ya think maybe Seabee's got a sense of humour or is he just "strange".:yawinkle:
Worse I knew a guy that drove his car with vise grip holding steering mount to frame , , some people need mandatory inspections , lucky he never killed anyone .That's so funny ... I can barely type ....lol
Yeah , don't be a "Puppy Killer" . Do it right .
Although , I once rode my dirtbike 10 miles with a vicegrip holding the axle in place .
Yeah... I was young....
Your a lot of help ..if thats all you have to say go away you must be single:wack:You guys are just so funny; Take the guy's serious thread and make jokes.Take the jokes into the proper forum.
Not necessarily true. This is a pretty common problem due as mentioned, to the less than stellar design of the threading surface. You have to judge how bad it is to decide on the right or best course of action. The best solution and the only thing to do if they have actually failed in service is to replace the arm. You can weld (not tack) one back in, but then you got a boogered up POS. If they just don't torque down right on replacement, tacking them in is a viable option.send them back...if they dont fit proper then they werent made proper....welding them in will work but ........they should fit right....Just sayin...........
You mean just "replace the control arm," right? You weld one in and that is the last one that arm will ever see, depending of course on your appetite for boogering up control arms....the only down side is you need to grind off the weld or replace the control arm the next time the ball joint needs to be replaced ...
I think I have an upper cntrl arm, if I do ...u can have it.
Thanks Bud. I got those Firm Feel UCA's a while back after my requests for a welder was shot down by the Mrs.. Everything has been fine so far.
A big expensive lesson learned: No more foreign parts, and no more craigslist fabricators.
jb weld? your nuts.. if anything have then actually tack welded in there.
Gorilla glue is awesome! But have you ever tried top get that stuff off your hands?gorilla glue is the best
my re-mark was intended for green guylol!
