Need to raise ride height
Mopar to ya
Rock Creek, Minnesota
I have my new mono leafs in and instead of the 1" lift promised, it lowered an inch. I adjusted the torsion bars to level the car, but my aftermarket skid plates, (headers) bottom out on occasion. I would like to raise the rear, then crank the torsion bars up a turn or two in the front. What is the best way to raise the rear. I have caltracs and can't use extended shackles, but I hate them anyway. Any suggestions?
Raise the front eye by whatever means available. If you raise the front only say 1" it will only raise the rear 1/2" though. Bummer they didn't give what they said. Might be able to find someone who has Caltracs that wants their car lower and swap.
Remove your mono leaf springs and have them re-arched.
Kenny
I,ve read about flipping your front hangers,but need to open up 1 or 2 holes for the studs to fit properly.Just a thought.:yawinkle:
I checked to see if I could flip my front hangers and you can't, they only go in one way.
you could just get add couple of helper leaves.
