turbo66valiant
Lookin Good so far!!!!
Looks like you need to keep a closer eye on your turbo toad...does she even know who the dad is?
Ryan that's great I thought it was pretty funny story that I needed to share.
I'm getting very close to firing the motor up I have a bunch of little things to get done beforehand though but I'm getting excited I hope all the long hours of hard work will pay off once I get her going ill give a detailed setup run down of the TOAD. Thanks again I couldn't have gotten this far without you and Tom and Bill's,FABO,.ORG help
Thanks again
Aaron
I haven't post in a minute good things are getting ready to happen I finished the down pipe and installed a wideband O2 sen. Electrical is just about done.
I still have to finish the fuel deliver setup but I have all the parts and pieces to get it done. Apparently I messed up my turbo oil feed and return lines so I have to do some minor repairs to that.
But I'm off tomorrow so if I can get the small things do done on my day off there is a good chance tomorrow just may be the day the TOAD SEES LIFE
AARON
UPDATED PHOTOS ON PHOTOBUCKET
Sounds good! So is the plan to break in the motor and then plumb in the turbo?
Yah that's the plan I had some issues with the head gasket but I believe I have taken care of the issue I plan on trying to break in the cam tomorrow I do have a small leak in the radiator that's going to have to be addressed as well but so far so good I haven't touched the timing yet
That thing looks awesome! Is the plan to run the intake through the firewall or something like that? I can't wait to see it all come together.
No I don't plan on running a intercooler just meth injection all the research I've done via the net pretty much says no intercooler is needed with meth injection up to around 600 HP so I'm going to see if that holds true
I'm just about ready to hook the cold side up all my pressure and leak tests are done and all the minor leaks are taking care of as soon as I receive a couple odd ball t clamps the TOAD will became a forced inducted freak of nature
Then the fun will began I get to try and tune it!!!!!!!!
Aaron
What meth kit are you going to use? AIS has some really good information on their site.
http://www.alcoholinjectionsystems.com/index.html
