72DartCustom
- Joined
- Apr 2, 2010
- Messages
- 130
- Reaction score
- 4
![IMG_1702.jpg](http://i382.photobucket.com/albums/oo263/Duster225/IMG_1702.jpg)
I cant wait to install these on my dart!!
Cool, what name brand?
Summit and Jegs have crazy fast shipping.
Cool man what they going on?
hey I have those on my dart! good luck hahaha they are a ***** to put on they hit in all kinds of places with my 1974 swinger 360 power steering they also make a noise from hitting the body and random other places on the car we had to work them out on the steering linkage and torsion bar on passanger side HAMMER!
here is those headers on my swinger open with the old 318
1974 sublime dart swinger - YouTube
I know, im thinking about 2-4 hours of work is ahead of me depending on how the installation goes. They sound great on your 318! Im just going to hate hammering these if the power steering gets in the way.. Ill be sure to post a video of mine when they are on. Thanks for the heads up!
Ya good luck it took us like 8 hours in the end spread over a couple of days just dont get discouraged they fit kinda odly we got rid of the studs and went with chrome hex head bolts the Power steering needs to come off if I remember correct so does steering linkage passanger side we got in through the bottom the driver side hahaha ya right VERY TIGHT
You you guyssssssssssssssss not good with the wrench or what he will have no problems.
Do you have any tips? this is my first header installation.
Yep as Cindy would say read the instructions well.Get started and were here to help.You know your going to drop your steering linkage right?
Dang, 8 hours? were you trying to feed them through the top instead of through the bottom? ha ha I plan on jacking up the car 2 feet on stands and jacking up the engine 3" like it recommends.
I bet it will take you close to 8 hours to put them on. I did mine in just shy of 8 hours and I had the front of the car more than 2 feet high, and the engine raised as high as I could get it.
It's the driver side that will get you. You may have to push the engine toward the left of the car to get it up in there. I think it took me close to 5 for that side, the passenger side was relatively easy in comparison. You will want to get the car as high as you can safely, especially for the driver side. You will also have to separate your steering cross link to run it through the header. You will more than likely run into a problem with your steering shaft depending on which connector is there.
Not trying to burst your bubble but that is the worst case scenario. Just take your time, work safely and try not to get frustrated. I myself would plan on a helper and a day.
