pishta
I know I'm right....
I have heard bad and good about their welder?
http://www.harborfreight.com/120-amp-230-volt-mig-and-flux-welder-97503.html
I have that one, but its an older model, DualMig 131 that is 110V (so I guess I dont have that model...?) . My wire drive wheel tensioner didnt seem to catch the .030 wire even cranked all the way down , so I flipped it and used the .025 side, works good now. Havent tried gas yet, and I even have a tank and regulator already. Mine was made in Italy and I got it cheap second hand. The guy said it didnt feed. I opened up the gun and found the weld wire was not even inside the coil, it had fed between the coil and the neck and jammed. No issues, but if you put a desk fan pointing at it, itll work longer before it thermal switch shuts down. I think they redesigned the feed tensioner because mine works on the long end of a strip of spring metal so you cant really tighten it down before the arm starts to bend (maybe by design?) I should get a new drive wheel if they offer it.
DONT get: Exhaust tube expanders (they strip the drive screw or break the anvil) and I have broken many of their long screwdrivers, but they have a lifetime warranty so I keep taking them back. I have their HD engine stand and the arms adjust, dont see how they cant fit a 360...And I have their breakdown cherry picker (upgrade all hardware to Grade 8) works fine but its a little shaky because its held to together with pins, but my buddy did pull a F350 Ford Diesel motor with trans with one, and that weighed close to 1/2 ton, braver than me.
