Belltek821
Member
I've got a 904 tranny that is leaking fluid. Its wet above the pan on the shift selector side. It started after I put a Hurst quarter stick in. It leaks while its sitting in the garage. There are times after I drive it that Ill put it away for a week and in wont leak a drop, but when it leaks it'll drop an 1/8 quart in a week. The old kick down selector is still there not attached to anything, not sure if I should just remove it all together. I suspect its leaking from around the selector lever. I've already replaced the transmission pan and gasket. Any ideas would be greatly appreciated.
69 Valiant
360
904 manual valve body
69 Valiant
360
