Bunch of 360 LA parts
FomocoReformed
Rhode Island, USA
Want to consolidate all the engine parts in one place. Have a bunch of 360 parts since I'm going a different direction with my build and won't need this stuff, I'll add parts as I think of them. It was a late 70's motor, factory 4 barrel. I believe it was an E58 engine, low miles came from a military vehicle.
Thermoquad carb, this is a smog carb - $30
596 heads - $80
Cloyes Timing set, single roller - $10
CFD cast crank - $50
Stock Rods - $10 a piece
Stock flat top pistons, one has some wear on the skirt - $40
Timing cover - $15
Harmonic damper/Balancer - $30
Valve covers - $25
Dipstick - $5
Edelbrock Torker II 340 intake - $80
360 block done up all nice nice, .30 over and honed, honed lifter bores, bead blasted, has new cam bearings and freeze plugs - $400
Truck motor mount brackets - $10
SB Solid motor mounts - $25
Cam thrust plate - $5
Other random bits off the original engine like the heat riser spring control thingabob, vacuum cannister smoggy thingy, triangle alternator bracket, bits and bolts, this little junk is all free free free. Let me know what you need I'll see if I've got it in a box somewhere.
I'm looking for a single groove water pump pulley with a deep tunnel., Do you have one?
PM sent on the portasnorkels and peedlepods.
PMs replied, those portasnorkels and peedlepods are rare parts these days, don't expect them to come at a low price :glasses7:
Edit: updated parts list, oil pump and rockers gone
Will the intake work on my 318 also can I get some pictures of the intake
Just saw the date of the original post so not sure if you still have these items
38 Dodge, the intake will not work on a 318 unless you are using 340/360 cylinder heads. It will not work on the closed chamber 318 heads.
Update though.
Cam thrust plate gone.
Block price dropped from $400 to $300
Everything arrived today and is exactly what I need. Thanks for a smooth transaction. :hello1:
i need a timing cover for my 1970 318..whats the number on the one u have it should be the same.
Sorry josh the timing cover is sold already. Thanks for the update grumpus!
Rotating assembly, timing cover, damper, dipstick, and valve covers are sold.
Block pending.
Thanks for the all parts. I would love to see pics of the dart when your done.Good luck with the build !! I Just noticed the alternator brackets in the thread, do you still have them along with the spacers?
Replied to all PMs, alt brackets are sold. This is what I have left, everything else is sold.
596 heads - $80
360 block done up all nice nice, .30 over and honed, honed lifter bores, bead blasted, has new cam bearings and freeze plugs - $300
