Oklacarcollecto
Life is an experiment
lildemonkid I am not sure we have different brackets. They do look similar. Either way it does show that the bracket mounts to the water pump which was a question.
As for the final setup. I was going to save the money and at least install everything then let a professional evacuate and fill the system. That way they can verify I have no leaks and everything is good.
There is a space for an idler pulley set up on his plus the braket looks larger.
