WTB motor/engine mounts
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
looking for small block engine/motor mounts ........for 318/340 into a pre-72 pad type mounts.......seller must take paypal since there is no way i can send a money order or check right now ....i will pay the paypal fees.
Do you need for a 340 or 318? One side is different for a 340.
actually putting two cars together ....one is a 340 and the other is actually a 360......so i was thinking that either will work on the 360 without shimming it so i was going to put the 318 ones on the 360 and the if i found the 340 ones, then those on the 340.
The 340-360 pad style engine bracket's are the same, left and right
side's. The 318 passenger side motor bracket will bolt right up. (only A-body
bracket's). The 318 Driver's side motor bracket will work, but you will
need the use of a spacer, for this side. I hope this make's sense to you.
Good luck.
I have THREE pairs of A body 340/360 brackets for Pad style K-members, I want $60.00/set, shipping included. They have the "skinnier" driver side bracket so they will bolt right up to the ears. Send me a PM if you want a set.
273/318 brackets are the SAME on the passenger side, but the driver side is wider and has one ear hole in the wrong spot. I made my own driver side out of a 318 bracket for my 360 into my 72 dart. I used a Truck 360 bracket and cut it out and rounded the edges as my "spacer ear". Bolted up and sat in the engine bay like it was meant to be there.
To echo all that's said above: If you are running a 340 and a 360 you need 340/360 mounts, not 273/318 mounts. Shimming won't work. There is an ear missing.
