805MoparKid, ya done stepped in it.
You said "they all use the same starter from the 60 slant to a gen 2 hemi, and LA/mag small blocks."
That's wrong. The '60-'61 slant-6s will not accept the '62-'88 Chrysler or '88-'01 Denso starter unless you change to a '62-up flywheel or torque converter. Neither will '63-'66 Canadian slant-6s, for the same reason. Neither will slant-6 truck, van, and heavy-duty car applications of any year with the 11" clutch. All these won't-fit applications need a starter with a 9-tooth, 25mm drive pinion. The Chrysler and Denso gear reduction starters have a 10-tooth, 33mm drive pinion.
And the Jeeps, even with 5.2 and 5.9 engines—Magnum and non-Magnum alike—use a totally different and non-interchangeable starter.
And yes, the Magnum small blocks existed past '01; see
here for example.
And no, there are no starters for Gen2 Hemi engines that will also fit slant-6s, 318s, 5.2s, 3.9s, 5.9s, etc.
Acknowledge it and learn the lesson it brings: when you give advice without knowing what you're talking about, someone who does know what you're talking about is probably going to come along and correct you. If you don't like being corrected, make sure your advice is solid before you give it.
