Post your wheel and tire combos.
FRONT: 15 x 4.5 E/T GASSERS TIRES: Nexen 165-80-15
REAR: 15 X 8 ROCKET RACING TIRES: Hankook 295-50-15
I like the look, needs different wheels though.
New rims and tires this summer following a disk brake and rear end upgrade. Boyd rims 17x7 and American Classic Red Line tires. 235/55/17. They fit great in the back but I had to trim and roll the front fenders.
My 71' swinger with 18x8 centerline 5" backspacing with 245/45 18 Nitto 555's rubber. I have been thinking of changing it up this up coming spring. Cars going through some changes this winter and I think I may move over to a more minister bad *** look from the current retro mod look. Maybe some 15" rims with alot of meat on them along with some narrower rims up front.
Hey folks
This is my setup:
Kumho 215-65/14 on all corners.
The wheel centers are the Brazilian equivalent of the US dog dish.
I'll be adding chrome rings to the wheels slots (not the rims) at some point in the future. These were in the Brazilian Charger and look really nice.
It looks ok and was cheap enough.
vbpgimage.php
FRONT 17X7 BS 4.25 on 215/50/17 KUMHOECSTA SPT Radials
BACK 17X8 BS 4.50 on 275/50/17 M&H Drag Radials
wheels are ROCKET RACING FUEL Polished
the back have MAYBE almost a 1/2 inch before the hit front of wheel well :) :wack:
Hey, the background of second picture looks familiar.... :D
1968 dart
front 15x6 american racing torque thurst 2 195/65x15 bfgoodrich
rear 15x10 american racing torque thurst 2 28x12.5x15 mickey thompson 4" back space
spring relocation mini tubbed
Went with Coy's C57's. 18x8 rear and 17x8 frt. both with 4.5 backspace. 235/40/18 and 215/40/17 all stock suspension. Switched the front to 225/45/17 to balance it out. still no problem with fitment.
Your Dart looks great with those wheels. Would you mind posting a pic from the front showing how far the front tire projects out into the fender? I'm trying to determine what backspace will allow me to tuck the tire inside the fender.
Also, is your front suspension at stock height?
Thanks, that helps. Looks like you are right at about the outer limit for the front. Very nice.
5 x 4 small bolt pattern Cragars - 15 x 7 ( 245 ) on the rear and 15 x6 ( 225 ) on the front love the way it handles !!
can you show direct front and rear shot's,I like the look and was thinking about the same tire and rim sizes for my '68.and that's a sharp looking dart you got there.
I'm sure a bunch of us have seen this Dart floating around the interwebs. I've been searching through out the four corners of the internets and can't find the specs.
I want the same exact tire/wheel combo for the front and back as in this dart. Apart from the wheel well cutouts, does anyone know if the owner mini-tubed it? I love the stance on it, to my opinion it is perfect and want such look on mine! =P
With my color combo (Gun Metal/black stripe/black hemi hood) I also think this look is good. I have the AlterK up front and SS springs (offset shackle, stock wheel wells) in back. I do, however, want to go with 16" wheels. That's the perfect size for my tastes. Seems like all of the steel Mopar wheels I come across are 14" and 15". I may also need a custom BS. Anyone know of a good shop that does custom steel wheel sizes? I'm in SE MI if local is a possibility. I think I'll go raw steel then have them painted the exact black of the stripe/hood to match (I didn't do flat). Good luck on your build!
OK, here is my setup.......
Wheels are Billet Specialties "Street Light"
Front 15 x 4 with 2.25" backspacing
BFG Radial T\A 155\80-15 (getting hard to find)
Rear 15 x 7 with 4.5" backspacing
BFG Radial T\A 235\70-15
It always amazes me how many nice a-bodies are out there.
This site is great. A lot of times I get occupied strolling through here. Meaning "For A-Bodies Only" I like all Mopars But The A-bodies are what I could afford to Play with . And do what I wanted to do to them without to much critisism from others. I am an old school mopar race fan so I like big tires and just could never keep those original skinnies on any car
Here are other old rides of many I had.
I would put these wheels on everything back then
