Post your wheel and tire combos.
1963 PLymouth Valiant V200
Front and Rear
Wheel Brand REV Classic 100
Size 15x7 5x4.5 BP
Backspacing 4" - w/ wheel adapters, B/S is 2.75"
Tire size 195/55/15 Nankang
Suspension mods none
I just got back from Willow Springs raceway with the Hotchkis suspension team and thought I would post what rim and tire combo worked on my 1969 Plymouth Valiant...
Sounds like a great combo - can't wait to see the pics! Doesn't hurt that I've got a soft spot for Valiants in general, and I think I saw your car at the Fling a few years back. Nice!
Clair
Front: 165SR15 on weld wheels frontend completely rebuilt with PST bushings over sized sway bar
Rear: 33x21.5x15 Mickeys on weld wheels. Fully tubbed 4 link, coil over, boxed frame.:cheers:
My Cuda with 17's ! Stroked 340, 727, 8 3/4, 4 wheel discs finished in Viper Red!
Front - 235-45-17
4.25 BS on rims
Rear -275-40-17
4.5 BS on rims
1973 Dart Sport 340
Front wheels 15"x4" 1 3/4" BS Jegs Sportlite 155/80/15 BF Goodrich TA Radial no mods to suspension
Rear wheels 15"x10" 4 1/2"BS Jegs Sportlite 275/60/15 BF Goodrich TA Radial no suspension mods
vbpgimage.php
This is my rear tire I'm still working on the front.
265/50-15 BFG TA (no longer made)
15x10 Keystone Classics
large bolt pattern rear out of 73 Duster
Stock 68 Barracuda fastback with the fender lip rolled a bit.
Front - 205/70/15 on 15 x 5.5 w/3.5 b/s, KH 4 piston redrilled to bbp
Rears - Had 235/60/15 on 15 x 7 w/4.5 bs w/11 x 2 brakes. Since then, I was able to sneak a 245/60/15 on the same wheel w/better than finger clearance to the lip and spring.
I'm still working on getting the front tire fitment perfect, but I got the rear hammered out. The front currently has 215/60R15 BFG Radial T/A's on 15x6 American Racing Torque Thrust II's. Front disc brake setup from 73-76 A-Body. Tires rub on front right fender on the frontward bottom corner. I think I'm going to change to a 205/65R15 Michelin HydroEdge (somewhat matches tread pattern of the Mickey Thompson ET Street Radials on the rear). Rear tires are 255/60R15 Mickey Thompson ET Street Radial on 15x8 American Racing Torque Thrust II's. Stock A-Body 8-3/4 w/ Moser axles and 11x2.5 drum brakes.
coys wheels 17x7 small bolt pattern 225/50s in front and 235/50s in the back they bolted right on with no issues great wheels 4.25 backspacing
205/70-14 Bfg's all the way around on 14"x4.5" Mopar steel wheels.
WOW!! that's one of the nicest Darts that I've ever seen. love the color, the Nascar stud w/ black steelies and the stripe. I live in So Cal and hope to see that Dart at a show. VERY NICE CAR.
I am looking for some chrome bearing dust caps for my 64 Gt, is there any available?
Thank you !
front 15x 4 weld wheels 560 15 vw tires,,and 33x 21.5 hoosier radials on 15x15 zero off set rims,,, 37 inch 8 3/4
Car year and model 1974 Dodge Dart Swinger
Front
Wheel Brand Chrysler Rallye Wheel
Size 14 x 6 with 5 x 4.5 BBP
Backspacing 4 Inch
tire size 205/70/14
Suspension mods None
Rear
Backspacing 4 Inch
tire size 205/70/14
Suspension mod None
do you have pics???
1975 Dodge Dart Sport
Front
Wheel Brand: - Summit "Pro-Star" knock-offs
Size: - 15 x 4
Backspacing: - 2.5"
Tire size: - 165/R15
Rear
Size: - 15 x 7
Backspacing: - 4"
Tire size: - 275/60R/15
The rears are a tight fit, but nothing rubs. :headbang:
Guys I need a little info.I have a 1970 Duster,I have 15x8 inch chrysler rallys I need to know what size tire I can put under the front and rear without rubbing.I was going to go with a 225 60 15 on the rear and a 215 60 15 on the front.Not to worried about the rear tires rubbing but Im afraid the front may rub when turning the wheels.Any info would greatly be appreciated.Thanks,Eddie.
All Rims are Crager SS 5 on 4
15*6 " Front 3" bs
215/60/15 BFG Radial T/A
15/8 " Rear 4 1/4" bs
255/60/15 BFG Radial T/A
No suspension mods front or rear. Rear tire to spring clearance a little over 3/4 in.No noticable problems front or rear.
15*6 " Front 3" bs
I ordered the same for my '67 cuda except the front end will have 15x7 Cragars (with a 4.125 rear spacing and 3mm offset).
I'm still waiting on my tires and wheels from Summit racing. I hope the 15x7 wheels fit and I don't experience and clearance issues.
