Darius
Darius
I am selling my 69 Dart GTS 340,727,3:23. I have had it for 6 years and I need room so unfortunately it has to go. My other build is almost done and I have a 2013 Charger Daytona on the way!
Here is the scoop:
This car is a west coast car. It was semi restored in the mid 80’s by a gentleman in Tacoma Wa. I spoke with him but he had suffered a stroke and the most I could get from him was that this car has a 70TA block and was rebuilt at that time. I have a pile of receipts from him and there is one from April 2000 from a tune up shop in Tacoma stating 2921 miles on the Odometer. It read 5211 when I bought it in April 2007.
I have a PILE of receipts from both the guy who restored it in the 80’s as well as everything I have done with it since I have had it. There is also some decent history data as relates to ownership names, numbers/contact info, etc.
Here is what I see has been changed/added in first resto based on fender tag decode by Frank at GTS Registry;
A/C was added, receipt in folder for 318 A/C stuff as well as rear defogger
Original top was black and was stripe delete. New to white and stripe added
Cruise control added. (Does not work, never has, I have not tried to fix it)
A/C works but needs a charge, I lost the charge when I changed the manifold. It worked fine before that as I had it re-done.
What I have done;
Changed cracked original intake to an Air Gap
Installed Edelbrock 4bbl carb
Removed de-fogger for speaker hole but I will include all parts with car
Added Satellite radio, will come with car but you subscribe.
Installed the complete Hotchkis TVS suspension, includes frame connectors and front and rear sway bars….this car is a GO CART now!!
Installed 2 ½” exhaust, custom fit around suspension, kept factory exhaust manifolds!
Mufflers are Dynomax super turbos, very acceptable noise level and NO cavitation drone
Installed new 15” Rally Wheels and trim small bolt pattern. Still has left and right threads.
Installed BF Goodrich radials, P225/60R15 at 105590 on odo.
This car is as mechanically sound as you will find. There is some rust at the bottom of the “C” pillars under the vinyl and a pinhole over the right rear wheel opening as well as under the right rocker behind the door. It needs a paint job but that is it!
Here is a link to a ton of pics on photo bucket.
I am asking $20,000 or best offer. I have about $9k just in theA/C,suspension, exhaust, and tires/wheels. I will entertain offers, not insults. I think I covered everything as well as I can with the pics but send questions if you have them.
http://s284.beta.photobucket.com/user/DariusCRCKBR/library/Dart for sale pics
Here is the scoop:
What I have done;
