sazzlefrats
I'm thinking this is probably a very bad sign. I bought my Dart 6 months ago, but because of a newborn, I sort of put it aside and haven't toyed with it since I got all the mechanicals hooked up.
I took her out of the garage yesterday and got her idleing and let it go for 20minutes. My brand new aluminum radiator boiled over and and this sludge is coming out. I've never seen anything quite like it.
I killed the motor which was idling just fine, it does bog when you stamp the gas pedal (a problem I was hoping to work on).
Anyhow when I could I took off the radiator cap, there was this greyish sludge all over it, it was super smooth to the touch. The motor didn't appear to radiating much heat (temp gauge does not appear to work). There was a slight amount of red in the sludge which I guess is rust. The motor has unknown miles on it. I'm pretty sure its a 360, worst case is its a 318.
Other than pulling the motor apart, cause I think its a head gasket, what else can I do to figure it out.
