E-brake over or under exhaust?
lee01
Cantley, Qc, Canada
Wondering were should the e-brake cable goes?
Over or under the exhaust?
I'm approching this step, and I just wanted to know which to install first.
Supposed to go on top near the floor....................
Above, there's no way you'll get them below the exhaust and still have them work right.
Keep in mind with the brake set the cables get tighter. Mine pull right up tight against the floor when the brake is set. If they rub a little on the exhaust when the brake is released its not a big deal, they shouldn't be under that much tension when released.
