I'm still using the 30% pulled from stock table (on first page). Haven't been on the dyno to add timing yet.
Tell me about your motor specs again- you might could use the factory timing table (or more).
Main things you'll use in tuner studio:
1- VE table
2- Spark table
3- auto tune
On the dyno my tune produced minimal torque. Might be worth addin timing closer to the stock table for you.
PM me your email. I'll send you the different timing tables I have.
I'd like to thank map63vette for the ride in his ms hemi swap dart. Also the info and details of his swap and being such a nice young man. Very nice car indeed and it runs so smoothly.
I will be going to ms3x route for sure. Just seems a better option to know the in and outs of my efi system. Instead of plug and go. I also want to go with a single coil and plug setup like the ls coils. Can I do this with the hemi reluctor wheel???
Is the MS3 Pro worth the extra money? Im kinda thinkin since I may have a harness to pilage, this would save so much $$$$. I can solder fine and I can wire. Only EFI experience I have is with an EZ EFI. And it liked a 14.0 idle, 13.5 cruise and about 12.3-12.5 WFO. You can aslo datalog with Ms3x and Pro no?
...........MS-3.........
There do appear to be a few changes to the board. You don't need to adjust the pots internally for crank and cam signals.
Looks like you still need coil drivers with it. And it requires an external MAP sensor.
To me, not having the MAP sensor integrated is an advantage. I'm not sure "anybody else" does this
I was talking one coil, one plug, per cylinder. Not 16 coils only a total only 8. Eliminate the second plug as it is not needed.
I'm not aware of anyone doing this. Are you? I 'm not sure I can agree with you that the second plug is 'not needed' - mopar wouldn't put it there otherwise.
Anyone know the main reason or list of reasons mopar put two plugs?
I believe the main reasoning behind the two plug setup was the original wasted spark design of the engine to help clean up the Hemi's somewhat notorious emisisons issues. The engines breathe so easy that they can pull intake charges straight through and out the exhaust port. The early engines had all the wires across the engine as you might recall, so one coil pack fired a plug in its respective cylinder and the one opposite it in regard to firing order. They weren't necessary designed to fire at the same time, though I see no reason they couldn't do this. Would potentially offer a more consistent flame front, but at the same time it can cause two wave fronts to collide which can be a big detonation problem.
The coils won't fire at my power level and are of mo use. When there isn't a dual coil capable of firing the energy I require. It is not applicable for me to use them.
How much boost are you looking to run?
Do tell
I've seen 1000 HP 6.1L Hemis with stock blocks built (Hot Rod built one), wonder if they last? Anyone have first hand experience?
Sorry for the off topic.
Regards,
Joe Dokes
I'm looking at 15-1700 @ probably 30psi or so. On different fuels to boot. Hoping for less. I've yet to decide on if ill buy the aluminum block with the tytech heads. A few have said my block will take it but I'm skeptical myself. Time and finances will tell.
