One of my cars is a 67 Barracuda notchback. I had a fresh 360 in it .020 over all stock except a performer RPM intake and 600 Holley 1850 carb. I came across a 360 / 380 horse power Mopar Performance crate engine that was brand new and decided to buy it and throw it in the car. I had read a lot of articles that stated these ran pretty good with a 750 Carb and headers. I thought it would be a considerable improvement over the engine I had in the car and could still run on pump gas. I swapped the engines and originally tried running it with the 600 carb from the old engine and 340 exhaust manifolds, and an original type distributor with a pertronix ignitor module installed. The car ran horrible. I borrowed a 750 Holley 3310 from one of my other cars along with a Mopar performance electronic distributor with an orange box. The engine ran a little better but idle was erratic and I could hear detonanation when the car shifted or when I gave it throttle. I tried initial timng at 10 before and kept backing it off but still had detonation and the engine wanted to run on after shutting it down. I checked engine vacuum and after seeing it had 5 inches of vac. at idle I switched to a 2.5 power valve which cured the idle problem but I still had detonation, run on and low performance. I had read where the advance curves for the Mopar Performance distributors was really quick and when I would try to use the vacuum advance on the distributor the detonation was worse. I bought a pertronix ignitor 3 mechanical advance distributor which comes with 3 sets of different tension springs and 3 different sets of advance limiters. I set the distributor up for 20 degrees of advance all in @ 3500 rpm. I set initial timing @ 10 degrees BTDC for a total of 30 degrees. I didn't want to try any more advance due to the detonation problems I was having. I took the car for a ride and there was no detonation but it still runs like a pig. I still have the 340 manifolds on the engine because I don't want to go through all the hassles associated with small block headers. Even the super expensive headers are a pain. I can't believe the manifolds are robbing that much power. The trans is a 727 with a B&M holeshot converter, the rearend is 81/4 with 321 gears. I know the converter and gears aren't the best to be running with this engine due to the single plane intake and cam profile but if this engine is even close to 380 HP in the best coditions I feel it should oerform better than it is. It sounds great at idle, it doesn't miss, pop, fart or anything. I'm running what is supposed to be 93 octane premium. Are these engines that over rated? Am I missing something obvious? I've been doing this a lot of years and have run everything from a 9 second 500 CI Duster to my 64 Fury with a bone stock Poly engine. I think my poly actually has more power than this crate engine. Anyone have any experience with these engines?
