Who makes an affordable wheel like this?
mopardrt
Detroit
Car is a 1974 swinger stock length 8 1/4 I am re-doing a set of 14" Magnum 500s right now, but not sure if I am going to stick with them, would like to move up to a 15" or bigger. Ordering 14" radials are getting so expensive....
So I am looking for an affordable set of rims that look like these, http://www.bossmotorsports.com/custom_chrome_wheels.cfm?id=1920&cat=467 Should I just keep looking for a set of the mustang pony rims that look like these or does someone else make a set that's affordably priced? I want black or silver/grey anything but chrome.
I say affordable, but I actually don't know what a new rim should cost seeing as I have never purchased a new wheel.
Take a stroll through the pages of Summit and Jegs.
Yeah, I just don't know how to search for just what I want, I would really like to find 4 of these,
Those boss 338 are a reasonable price .I believe a member here dealt with Jdwheels.com.
ok, let me get you started.
http://www.summitracing.com/search/...t-type/wheels/wheel-bolt-pattern/5-x-4-1-2-in
Now, narrow your search parameters using the section on the left side of the screen. How wide do you want? what offset? what diameter? its all tweakable to narrow your results. Try it out. That's how I find stuff on Summit all the time
here's one: http://www.summitracing.com/parts/sum-141-5865gm0/overview/
Hey thanks, I use summit all the time I just don't know the offset I need or back space
yeah, that's kinda important info that can affect wheel choice. and you'll be surprise the stuff people over look. I may be 22but overlooked that side for a while lol
Yeah, I know the mustang rims fit the A bodys I just don't know if all years fit.
Lots of options out there. Not all Mustang rims will fit a stock set up car, most have too much backspace, especially in the back.
What size rims are you looking to run? 15x8's? 17's, 18's? And what size tires would you like to run with them?
I would like to get something in the 17" range that way I can get good tire deals and I could find used tires if need be, finding 14" and even 15" used or new radials is like next to impossible
