Neither one? That is odd. They branch off from the under dash harness, the same wires that go to the front signals
You can download the service manual here, the 73 manual is new, it's the last or one of the last posts in that thread
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
Thanks, by the way, to TrailBeast for hosting the file
www.letsgocomputers.com/docs/1973dodgebody.pdf
www.letsgocomputers.com/docs/1973dodgechassis.pdf
A body index is page 8-152
A body wiring begins 8-154
Diagram location A-18, page 8-158 shows the lamps
wire D10-18 LGN, and D9-18T (lt green and a tan)
If you go back one page, it appears they branch right there at the TS switch, connector CI-23 so if we go look up that connector which is on page 8-169, that is exactly what we find.......two tans, and two light greens coming off that connector. One of those goes up to the dash, one goes through the bulkhead to the turn signal.
Might be bad connections at / in the cluster, bad bulbs, bad sockets. I can think of no good explanation as to why both would just happen to fail. The signals all work normally?
