fbcuda69
NEW SSBC Brake Conversion Kit 1963-1972 Mopar A-Body part# A153-2 - I bought this kit thinking I was going to do the big brake 5 x 4.5 bolt pattern setup on the front of my 1969 Plymouth Barracuda, but ended up staying with the original kelsey hayes set up instead and have now sold car. This kit is unused and complete for doing two wheels and is the Better SSBC kit with the slotted rotors and anodized aluminum calipers. I believe this could fit a number of A bodies and maybe even a few B body cars, but please check part number above for your application. $800*, *SHIPPING NOW INCLUDED (*continental 48 U.S. Only) Thanks ; Local Pick up price: $750
P.S.- I would much prefer not having to ship, due to sending two boxes because of shipping weight, but will consider shipping if needed to be.
UPDATE: Question was raised regarding part# and not being on SSBC web site. It is true that A153-2 does not show up anymore, but a153-1 still does. I believe SSBC has superseded my package with another number maybe because of now using a different type caliper. A153-2 still shows up on the Yearone website if anybody wants to check; and you will notice that the price has been lowered to $1249* (*discount exempt); $450 more than what I am asking. I included another pic of what my setup would look like along with a brief description regarding the package. PLEASE NOTE MY SETUP HAS CLEAR ANONDIZED ALUMINUM CALIPERS NOT BLACK.
If you want to find out more detailed info on the kit you can still go to the SSBC web site and look at the A153-1 package; my package would have all the same parts, but two much better upgrades; Slotted Rotors and Anodized Aluminum Calipers, thus the A153-2 designation used by SSBC and Not the 1. The 1 package has steel calipers and plain rotors; this is the reason the 2 package was a few hundred dollars more than the 1.
Hope this helps; pm me if you have further questions.
This is the summary on the other site I mentioned:
Part Number:9413-A153-2 * Discount Exempt
Stainless Steel Brakes Corporation Force 10 disc maual brake kit for 1965-1972 Mopar A-body models without 9" front drum brakes.
Stainless Steel Brakes Corp disc brake conversion kit includes everything you need to convert your drum brakes to disc brakes. This kit is designed to work with your original spindles. only. Uses RH lugs only. Kit includes:4-piston aluminum calipers, performance pads, Turbo-Slot vented 11" rotors, master cylinder, adjustable proportioning valve with gauge, braided-steel brake lines, brackets, bearings and seals, hardware and instructions.
key words: cuda, valiant, demon, roadrunner, super bee, charger,
